Starlord
10 sign-ins 5 replies posted 5 questions asked
Hi All,
Since I am new to Murata chips, I would like to know what is the recommended IDE for development. I know that WICED SDK supports Murata, after installing a patch file. Is it possible to use STM32 Cube IDE with the help of STM32 Connectivity Package, for the development? If so, is there any way to get the ioc file to start with? Thanks for the help in advance
regards
SR
DheerajPK_41
Update:
As in the user manual, H7 series is supported. F4 is old and not supported in the connectivity package.
DheerajPK_41
Please check https://github.com/Infineon/stm32-connectivity
User can choose the compiler toolchain and IDE, and adapt the source code to any STM microcontroller to run the application. Regarding the ioc file, we will check and get back to you.
-Dheeraj.P.K
Thanks for the reply. I have already verified the connectivity package and it says it supports only H7 series. Please see below,
We uses Type 1LD and it has a STM32F4 core. Hence we think we need an ioc file which has all connections between STM32F4 and Cypress combo chip inside Type 1LD module. Could you please comment on this?
regards
SR
DheerajPK_41
Update:
