Per WICED Wi-Fi 101: Chapter 6​ here
I'm having trouble setting up the client/server example.
I want to see this example run in its most simple form before anything else. I'm adjusting the wifi_config_dct.h file to include the appropriate CLIENT_AP_SSID & CLIENT_AP_PASSPHRASE for my AP. That's the only thing I'm changing at the moment.
Maybe I'm just misunderstanding something along the way, too. I have two WICED Wifi boards. The first board is programmed with the client firmware. The second board is programmed with the server firmware. The client board should open a socket to the server board.
