Sep 21, 2018
03:14 AM
Sep 21, 2018
03:14 AM
As a follow on to this thread here: Re: SPI DMA and memory to memory DMA example for CYW43907
By using 43907, SPI DMA as well as memory to memory DMA is not possible in application layer. Actually, my application is moving lots of data from SPI then on the internet. Is 43907 suitable for such application ? Or, any other methods using 43907 or other chips that can recommended ?
11:39 PM
Sep 23, 2018
11:39 PM
The primary limitation in implementing this in your application would be the SPI Bandwidth.
Since this is now running in the application you will have to make sure your application is not too large and the thread that is doing the SPI transfer is getting sufficient time to complete the transfers.
Winston
Winston
