Wi-Fi Combo Forum Discussions
SaGa_2657031
Hi Guys,
Similar to this thread: OpenOCD Failed
I am also facing the same issue. Below is the log captured in build/openocd_log.txt.
Open On-Chip Debugger 0.10.0-dev-00225-gb0314be-dirty (2017-03-09-14:50)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
Info : only one transport option; autoselect 'jtag'
trst_and_srst separate srst_gates_jtag trst_push_pull srst_open_drain connect_deassert_srst
adapter speed: 1000 kHz
adapter_nsrst_delay: 100
jtag_ntrst_delay: 100
Warn : target name is deprecated use: 'cortex_m'
jtag_init
Warn : Using DEPRECATED interface driver 'ft2232'
Info : Consider using the 'ftdi' interface driver, with configuration files in interface/ftdi/...
Error: unable to open ftdi device: device not found
jtag_init
jtag_init
jtag_init
jtag_init
jtag_init
jtag_init
PriyaM_16
25 solutions authored 10 solutions authored 5 solutions authored
This problem usualy happens when the board do not bind to the correct drivers. Kindly check your device manager to verify that the board is bind to libusb drivers.
Please let us know if you are still facing issue in programming through Olimex.
ViMo_3310646
This seems to be your problem. You should be able to see the device either in your device manager(windows) or in /dev (linux) once it's plugged in. If not, you have to re-check your FTDI driver installation.
In my case I found that SW7 was in the incorrect position, it should be in Kitprog2 position. Appears I bumped the switch on the bottom of the board.
PriyaM_16
