MiBo_4070331
First like received
As a follow on to this thread: No Platforms in Wiced Studio Setup
Was this problem ever resolved? I am running windows 10 and experienced this exact problem (only a tools folder in 43xxx_Wi-Fi folder - everything else missing) with Wiced6.2. I tried 6.1 and it installed just fine.
AnjanaM_61
5 comments on KBA First comment on KBA 5 questions asked
Please check if the 'config.eml' file is copied in the same folder as the WICED installer file before installation.
If not, copy it and install again.
Anjana
AnjanaM_61
Anjana
Thanks. I didn't realize that file was required for the install exe to work properly.
