viku_4036306
Hi all,
     We are using BCM43907 controller, for the purpose of  decoding audio signal. when it is connected with wifi signal through access point, What is the Rssi value set before the decoder looks for the next Access point? Typically the device should have the primary Access point based on best signal and neighbor APs as backup if signal or Primary drops.
Presently Optimum bandwith roaming trigger has been set.
Thanks in advance..
VinayakS_26
100 replies posted 50 replies posted 25 replies posted
I believe you are looking for the roam threshold after which your station starts searching for a new AP.
Please try the following wl command
wl roam_trigger
wl roamscan_parms
returns the roam threshold.
VinayakS_26
VinayakS_26
wl roam_trigger
wl roamscan_parms
VinayakS_26
