Is it possible to get the Received Signal Strength Indication (RSSI) of individual packets received in monitoring mode, i.e. Probe Request, Beacon, etc ?
I've searched the community pages, and I've found questions regarding this dating back to 2015. However, I haven't found any solutions.
Any help is much appreciated.
I'm running:
WICED version: Wiced_006.002.001.0002
Chip: CYW43907
/Jesper
Wifi+Bluetooth
Radiotap headers are not supported within the Broad Market.
Hello:
I just use a sniffer to check the signal level value, I found the signal value is stable relatively . I have checked probe request, QoS null, 80211 Auth , 80211 BAR . So our get_rssi function should match your request.
Could you elaborate a little on the exact API function you are referring to?
Remember I have the device running in monitoring mode. What I have is roughly based on the example 'snip.packet_filter'.
I've registered a callback function to process packets with:
wwd_wifi_set_raw_packet_processor( raw_packet_callback );
and enabled monitoring mode with:
wwd_wifi_enable_monitor_mode();
The callback looks like this:
static void raw_packet_callback( wiced_buffer_t buffer, wwd_interface_t interface ) {
UNUSED_PARAMETER( interface );
void *raw = host_buffer_get_current_piece_data_pointer( buffer );
// Here I'd like to register the devices active on the WIFI channel
// Specifically I want to register their signal strength
host_buffer_release( buffer, WWD_NETWORK_RX );
If I try to use the API function wwd_wifi_get_rssi in the callback the return value is a TIMEOUT.
/Jesper
Hi:
I think you need a packet radiotap info which includes signal Level . we can see it from wireshark capture . Unfortunately I can't find any interface that indicates what we capture already includes the radiotap info.
Radiotap info is exactly what I need, however the only reference to radiotap in the entire SDK is a single header file. This file is, however, not used anywhere in the SDK, and there is no documentation on how to get/enable radiotap information.
Has anyone made use of radiotap info on the Cypress platform?
/Jesper
