Wi-Fi Combo
cblack-f3
New Contributor
Hi all, new to the community and have just started evaluation of the CYW parts.  I just downloaded the latest WICED Studio (6.6) and was stopped short in the README:
***PLEASE*** read through the WICED Quickstart Guide located
in the <WICED-SDK>/Doc directory before attempting to use any of
the applications in the application sub-directories!
Problem is, the only thing in the  <WICED-SDK>/Doc folder is "WICED-Studio-License-1.0.pdf"
So, where is this WICED Quickstart Guide, which based on this comment appears to be quite useful
Rakesh_BG
Hi @cblack-f3
The WICED Quickstart Guide is available at WICED-SDK\43xxx_Wi-Fi\doc
WICED-QSG.pdf is the document name of the Quick start Guide.
Rakesh_BG
Hi @cblack-f3
cblack-f3
New Contributor
Thanks, you may want to update that readme.txt so it points to an existing doc
