Quicksilver IoT Development Kit problem with example code
user_4727216
Hello
I have problem with Quicksilver IoT Development Kit.
Do you have information how build example program for this MCU?
When I click Build 'Defaul' for project 43xxx_Wi-Fi
I have this communicat:
Can sameone please take the time and showe me how to compile example program for this board and how upload for the MCU.
I have this version of Wiced:
StaryAnoda
Looks like there is some issue with your WICED installation.
Can you try to reinstall WICED and see if it helps out.
In the file path to your make.exe, I see a space, this may also be causing the issue. Can you check?
Murali_R
250 sign-ins 250 replies posted 100 solutions authored
@user_4727216 Your make target should look something like this. snip.scan-Quicksilver_EVL download run
You can use this video series as a starting point https://www.cypress.com/training/wiced-wi-fi-101-video-tutorial-series
user_4727216
Hello
I tried to build according to this quide. I get such problems:
