Dear,
I am testing the OTA Update using the program of snip.ota_fr in WICED SDK v2.4.1.
The comments in this ota_fr.c told me that the first step is running this command as follow:
snip.ota_fr-BCM943362WCD4 OTA=waf.ota_upgrade SFLASH=app-dct-ota-download
The platform I used is BCM9WCDUSI09, so I changed the command as:
snip.ota_fr-BCM9WCDUSI09 OTA=waf.ota_upgrade SFLASH=app-dct-ota-download
But it failed. Is the RAM too small?
The Log is in the attachment.
Could anyone help me to find the problem? Thanks.
BTW, the SPI Flash in my board is 4MByte.
Over The Air Updates (OTA)
I do not modify the file,you can fine sflash_get_size() func,and in the func you can know,it only supports SFLASH_SUPPORT_MACRONIX_PARTS and SFLASH_SUPPORT_SST_PARTS menufacture`s device,and the flash id must be SFLASH_ID_MX25L8006E or SFLASH_ID_SST25VF080B.Acturally i do not know bcm do like this.if your flash does not match,you will get the size of flash 0 size.
