Hello.
I have to develop an "oscilloscope-like application" with WICED.
The application has to send 1024Byte wide packets over WiFi Direct.
The packets are generated at a rate of 30 pakets/sec.
The 1024 bytes in the packets are to be plotted on a Tablet in a RealTime way.
My first question is : is it preferible to use TCP or UDP ??
For now I'm using TCP an I see wiced_tcp_set_type_of_service API that can tell to TCP stack how treat packets (Like Video Stream, Audio, ...).
I understand that I have to use Video Sream ... I'm correct ??
TCPIP
WICED Studio
Wireless MCU
Hello:
My suggestion is UDP , yes, video stream, we have customers who are using the wifi on camera project.
UDP is preferred, because in a noisy environment the T/P is not always stable, if you do re-transmission always, the pic or video will be blocked in a higher frequence.
Hello:
