MaFa_974161
100 sign-ins 50 replies posted 50 questions asked
I'm running "test.console-CYW943907AEVAL1F download run"
on WICED board ...
I have seen the command p2p_discovery_enable
and I see that can accept argument "listen".
What is the difference between launch the command with "listen" or not ?
Murali_R
250 sign-ins 250 replies posted 100 solutions authored
MaFa_974161
There is some discussion about p2p here in this thread Re: WiFi-Direct group owner with WICED: how to do? Can you please look at it and see if it helps as it has some detailed discussion on the topic?
Also, with listen passed in the parameter of p2p_discovery_enable , it basically enables the discovery mode for other devices to discover it.
Murali_R
MaFa_974161
