I have the following:
- WICED SDK 6.1
- SEGGGER J-link Base
- Ubuntu 16.04
I'm building the following make target snip.scan-BCM43362WCD4. We have a custom board with the USI module WM-N-BM-14, I'd like to know if there are some significant changes required in the platform files.
We are seeing the following issues:
Unable to debug with WICED Studio, I see the following error (using the following 43xxx_Wi-Fi_Debug_Linux64 debug with JTAG device: J-Link) :
Using Ozone, and the snip-gpio-BCM43362WCD4.elf. I see that the target in-consistently hits the WDT ISR.
There are two blog posts for downloading through Jlink segger in WICED. Can you check if it helps? Downloading through Jlink Segger in WICED SDK 6.2 and future releases and Downloading and debugging CYW43907 using Jlink Segger
Please let me know if you are still facing issues with this.
Moving to Universal Scientific Industrial (USI) support portal, adding jone_yi_1844281 from USI.
mifo Mike, I think this issue should be general SDK issue not specific for USI WM-N-BM-14 platform.
Would you move it back to SDK forum?!
I think krithik_3442281 still missing some part !
Here are some reference URL list detail about the eclipse run jlink on Ubuntu
I think the BCM943362WCD4 platform is not work on our WM-N-BM-14!
Please ask WM-N-BM-14 platform file from your local distributor!
Ok, I was able to compile and get the gpio, scan demo's working with platform files from a previous version of the sdk that did not have homekit. Now using BCM9WCDPLUS114.
However, the debugger not working with the IDE is an isolated issue. Can you point me to any documentation on setting up JTAG with the J-Link debugger for an Ubuntu Machine.
