Program "g++" not found in PATH, Porgram"gcc" not found in PATH
AnSh_4727841
I get the above errors when I try to build a make target.
Here's a community thread talking about adding C++ support in WICED: Compile a C++ file
But please be advised, if you are trying to integrate C++ in WICED in which the code uses a C compiler, it may cause some compilation issues as there maybe a clash between the files Especially, when you mix different header (stdc and c++) types that is different C libraries and a c++ application.
Murali_R
250 sign-ins 250 replies posted 100 solutions authored
Hello AnSh_4727841
Are you trying to add support for C++ ?
Which is the SDK that you are using?
I am using WICED SDK.
