Hi @ all!
My HW (SN8000) try to join to an AP (LinkSys). Used mode is WPA2 and the HW is only activated as client.
Now I find a strange behavior, when I change the channel on the AP (including power cycle for clean startup)
- Channel 1-6 and 13 works fine (join takes 5-6s)
- On channel 7-10 I have a long time (~15s and more) until the join is complete, sometimes it fails
=> Is there any settings or software behavior for different channels?
=> Anyone see the same problems? (or similar)
Thanks for helping,
Jan Gottwald
Dear
Some of people or device may use traffic a lot at channel 7-10.
So you can test it a night(nobody use the Air time).
Or  find another AP and test it again
For AIR check( wifi ap channel info) go to google play and download  "wifi analyze"  then you can see the air.
Tks
thanks for this hint! (Apple products + wireshark is an good option, too)
I just find out there may be a HW issue. Done here for now...
