Hi
I just instaled ide , i wanted start working and on begin my work first application hangs - what coudl happend ?
21:27:36.046>
21:27:36.046> Starting WICED v3.1.2
21:27:36.046> Platform BCM943362WCD4 initialised
21:27:36.046> Started ThreadX v5.6
21:27:36.046> Initialising NetX_Duo v5.7_sp1
21:27:36.046> Creating Packet pools
21:27:36.984> Waiting for scan results...
21:27:37.046> # Type BSSID RSSI Rate Chan Security SSID
21:27:37.046> ----------------------------------------------------------------------------------------------
SPI
Please try applying patch on following thread.
Which board do you use?
Your software assumes that BCM43362 is connected with STM32.
But it seems to be not available.
HI
WM-N-BM-09_EVB_V11
Seems your WLAN firmware is not loaded.
I normal case, booting should include below lines:
WWD XXXXX interface initialised
WLAN MAC Address : xx:xx:xx:xx:xx:xx
WLAN Firmware : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Hi ,
I faced the same issue when the RESET PIN for the WLAN was not connected properly..
