Oct 22, 2014
03:57 PM
Oct 22, 2014
03:57 PM
I am trying to debug a simple program, testing PWM, but when I initiate the debugger get a message stating 'Launching WICED debug' has encountered a problem
Error in final launch sequence
The screen shot is attached.
I have reviewed the step by step setup for debugging and the settings appear to be the same. The target I am using is an: ISM43362_M3G_L44
I am able to build and download and run other apps.
Thanks in advance.
04:12 PM
Oct 22, 2014
04:12 PM
It works for me as expected.
Did you take a look at Creating and/or Editing Debug Configurations?
-Seyhan
Oct 22, 2014
04:30 PM
Oct 22, 2014
04:30 PM
Setting the correct gdb in eclipse debugging will solve this issue as Seyhan mentioned.
Thnx,
Vikram
