Wi-Fi Combo Forum Discussions
KaAu_4610386
First like received
Greetings,
I am new to WICED, but I have a more or less fundamental problem that have been puzzling my colleague (who already had some experience with WICED) and me already for some time.
So, I installed the same version as WICED as my colleague. He gave me his project files. After having been programmed, the device keeps power cycling. When my colleague re-programs it, the device is fine. The same issue happens with other devices of the same kind. Installing an older version of WICED didn't help either. I installed WICED on another machine (with full administrating rights), the issue with power cycling remained.
I would appreciate any suggestions on what else we could look into or ways to troubleshoot!
Best,
kauerbach
GregG_16
25 sign-ins 25 comments on KBA 10 comments on KBA
Which device/kit are you using?
It's a custom board that uses CY8C6247BZI-D54 . However, it looks more like the WICED installation problem than a device issue...
For CY8C6247BZI-D54 part, you need to use PSoC creator for programming- https://www.cypress.com/part/cy8c6247bzi-d54
