I wonder if it's possible that there was a bug introduced in 3.5.2 that caused wiced_framework_set_boot() to fail.
We have developed our own OTA system, and in 3.5.2 the following returns WICED_ERROR:
result = wiced_framework_set_boot( DCT_APP0_INDEX, WICED_FRAMEWORK_LOAD_ONCE );
I traced this down finally to some code in wiced_waf_common.c that I believe is now erroneous considering the changes to the way wiced_dct_write() has been modified under 3.5.2. The existing code looks like this:
wiced_result_t wiced_waf_app_set_boot(uint8_t app_id, char load_once)
boot_detail_t boot;
boot.entry_point = 0;
boot.load_details.load_once = load_once;
boot.load_details.valid = 1;
boot.load_details.destination.id = INTERNAL;
if ( wiced_dct_get_app_header_location( app_id, &boot.load_details.source ) != WICED_SUCCESS )
return WICED_ERROR;
if ( wiced_dct_write( &boot, DCT_INTERNAL_SECTION, OFFSETOF( platform_dct_header_t, boot_detail ), sizeof(boot_detail_t) ) != WICED_SUCCESS )
return WICED_ERROR;
return WICED_SUCCESS;
I noted that a new function was introduced in 3.5.2 to do the job of setting boot parameters. I modified the above code to look like the following:
boot_detail_t boot;
return WICED_ERROR;
return wiced_dct_write_boot_details ( &boot );
I'd just like to confirm that what I've done is correct, and that there is indeed a bug. Or, if I am missing something, please let me know.
Yes, skrawat, the code I provided above compiles under 3.5.2, and is now working for us.
