Possible 3.5.2 bug in wiced_framework_set_boot()
I wonder if it's possible that there was a bug introduced in 3.5.2 that caused wiced_framework_set_boot() to fail.
We have developed our own OTA system, and in 3.5.2 the following returns WICED_ERROR:
   result = wiced_framework_set_boot( DCT_APP0_INDEX, WICED_FRAMEWORK_LOAD_ONCE );
I traced this down finally to some code in wiced_waf_common.c that I believe is now erroneous considering the changes to the way wiced_dct_write() has been modified under 3.5.2.   The existing code looks like this:
wiced_result_t wiced_waf_app_set_boot(uint8_t app_id, char load_once)
     boot_detail_t boot;
     boot.entry_point                 = 0;
     boot.load_details.load_once      = load_once;
     boot.load_details.valid          = 1;
     boot.load_details.destination.id = INTERNAL;
     if ( wiced_dct_get_app_header_location( app_id, &boot.load_details.source ) != WICED_SUCCESS )
         return WICED_ERROR;
     if ( wiced_dct_write( &boot, DCT_INTERNAL_SECTION, OFFSETOF( platform_dct_header_t, boot_detail ), sizeof(boot_detail_t) ) != WICED_SUCCESS )
         return WICED_ERROR;
     return WICED_SUCCESS;
I noted that a new function was introduced in 3.5.2 to do the job of setting boot parameters.  I modified the above code to look like the following:
     boot_detail_t boot;
         return WICED_ERROR;
     return wiced_dct_write_boot_details ( &boot );
I'd just like to confirm that what I've done is correct, and that there is indeed a bug.  Or, if I am missing something, please let me know.
Yes, skrawat, the code I provided above compiles under 3.5.2, and is now working for us.
We have exactly same issue and I think garywiz made a point.
( wiced_dct_write() will return WICED_ERROR for writing boot_detail )
Can SDK team confirm on this ?
Though I reported on a separate thread not knowing already one thread opened for this issue. i am also getting same issue.
garywiz does your workaround change in code compile and work ?
Thanks a lot gary, Your change worked for me. It would be good to know if broadcom approves it across the platforms as finally I have to use it over murata module.
Thanks Gary, I also ran into this and your solution is working for me as well. Thanks!
Hello Friends,
thanks for your valuable answer,
the issue of the restart solved but wifi module stuck at
"Writing chuck 1 of size 1024 from offset 0"  and it do nothing.
have you any idea about it , so please help us...
