Platform BCM9WCDUSI09
adityadubey
First question asked Welcome!
I have to upgrade the code from Wiced 2.3 to Wiced 6.6 in which I used Platform BCM9WCDUSI09.
In platform BCM9WCDUSI09 for WLAN BCM43362A2 is used, which is not available in Wiced 6.6.
Can I used old platform i.e BCM9WCDUSI09 in Wiced 6.6 with lates WLAN firmware 5.90.230.38.
If yes then how should I proceed further.
Phanindra_I
250 sign-ins 10 likes given 25 likes received
WICED is NRND and we recommend you to move to ModusToolbox if possible. Wiced 2.3 is a very old version and there are lot of changes in WICED 6.6 from 2.3. The way would be to paste the bsp of the board in "/platforms" folder. After this, you can try building application but I'm sure you might get build errors.
Phanindra_I
