I'm having issues connecting to a basic PEAP-MSCHAPv2 configuration. My Android phone can connect just fine using PEAP and MSCHAPv2 as the inner type.
However, with both the command console demo and writing raw code in WICED, I am unable to get anything except for return code 1007. I think I have tried every single combination of parameters in the wiced command console demo.
I am not seeing any connection attempts at all on my FreeRadius server. I feel like I must just be passing in some incorrect parameters:
Note: I use find_ap to scan for my desired access point, with the results being stored in ap_info.
memset(&conn_info, 0x0, sizeof(conn_info));
conn_info.interface = WWD_STA_INTERFACE;
conn_info.tls_identity = &identity;
conn_info.tls_session = &tls_session;
conn_info.context = &context;
conn_info.trusted_ca_certificates = NULL;
conn_info.root_ca_cert_length = 0;
conn_info.eap_type = EAP_TYPE_PEAP;
conn_info.inner_eap_type = EAP_TYPE_MSCHAPV2;
conn_info.auth_type = ap_info.security;
conn_info.eap_identity = eap_identity;
conn_info.user_name = "MY_USERNAME";
conn_info.password = "MY_PASSWORD";
wiced_log_printf("# Root CA Certs: %d\r\n", conn_info.root_ca_cert_length);
wiced_log_printf("EAP Type: %d\r\n", conn_info.eap_type);
wiced_log_printf("Inner EAP Type: %d\r\n", conn_info.inner_eap_type);
wiced_log_printf("Auth Type: %d\r\n", conn_info.auth_type);
wiced_log_printf("Username: %s\r\n", conn_info.user_name);
wiced_log_printf("Password: %s\r\n", conn_info.password);
if (fs_res == WICED_SUCCESS)
wiced_log_printf("Initializing BESL supplicant\r\n");
res = besl_supplicant_init(&supplicant_workspace, &conn_info);
if (res == BESL_SUCCESS)
wiced_log_printf("Starting BESL supplicant\r\n");
if (besl_supplicant_start(&supplicant_workspace) == BESL_SUCCESS)
wiced_log_printf("Initiating WiFi Join\r\n");
wiced_result_t wifi_join_res = wwd_wifi_join_specific(&ap_info, NULL, 0, NULL, WWD_STA_INTERFACE);
wiced_log_printf("WiFi Join Result: %d\r\n", wifi_join_res);
if (wifi_join_res == WICED_SUCCESS)
wiced_log_printf("Retrieving TLS session information\r\n");
int ret;
if ((ret = mbedtls_ssl_get_session(
&supplicant_workspace.tls_context->context,
&tls_session)) != 0)
wiced_log_printf(
" Failed to retrieve the session information %d \r\n",
ret);
else
wiced_log_printf(
" Successfully retrieved the session information %d \r\n",
ret);
else
res = besl_supplicant_stop(&supplicant_workspace);
if (res != BESL_SUCCESS)
wiced_log_printf(
"supplicant Stop failed with error = [%d]\r\n",
res);
wiced_log_printf("De-init supplicant\r\n");
besl_supplicant_deinit(&supplicant_workspace);
res = wifi_join_res;
else
wiced_log_printf("Unable to initialize supplicant. Error = [%d]\r\n",
res);
else
res = WICED_ERROR;
WICED Studio
Wifi+Bluetooth
