On compiling the Test Console App I get the following message:
Making test_console-TWRK60D100M.elf
c:/users/016424/documents/wiced/wiced-sdk-2.4.0/wiced-sdk/tools/arm_gnu/bin/win32/arm-none-eabi-ld.exe: build/test_console-TWRK60D100M/Binary/test_console-TWRK60D100M.elf section `.text' will not fit in region `APP_CODE'
c:/users/016424/documents/wiced/wiced-sdk-2.4.0/wiced-sdk/tools/arm_gnu/bin/win32/arm-none-eabi-ld.exe: region `APP_CODE' overflowed by 22448 bytes
What is the procedure within the WICED SDK for compiler optimization to optimize the code for size? (to create more compact code?)
Thanks!
Peter
- code size
- gcc options
Hi Peter,
If you don't need iperf, you can remove it by modifying console.mk.
It will reduce the code size much.
Hi Peter,
It's already optimized by -O3.
Please see build//test_console-TWRK60D100M/config.mk
You can modify wiced_toolchain_ARM_GNU.mk for -Os.
But I'm not sure over 22KB can be shrunk.
dmiya
Thanks for your insight on this!
That -Os compiler optimization setting reduced the 22KB overflow down to a 6KB overflow but as you anticipated this not enough to get the code to fit within the MCU's 512KB of flash.
Peter
Hi Peter,
