05:49 AM
Oct 23, 2014
05:49 AM
I'm using USI module WN-BM-14. It is mounted on eval board WM-N-BM-11 EVT.
I've issues to dowload code through USB
Downloading Bootloader ...
"**** OpenOCD failed - ensure you have installed the driver from the drivers directory, and that the debugger is not running **** In Linux this may be due to USB access permissions. In a virtual machine it may be due to USB passthrough settings. Check in the task list that another OpenOCD process is not running.
i'm using a very simple code "snip scan".
I could run the same code for BCM94362WCD4 : just compiling, plugin USB and done!
Any idea ?
Lionel
