- Email to a Friend
My ota2 project is not building when I add the debug option to the build config.
InVue.RTD-InVue_RTD-FreeRTOS-LwIP-debug ota2_manuf_download will not build but InVue.RTD-InVue_RTD-FreeRTOS-LwIP ota2_manuf_download will and InVue.RTD-InVue_RTD-FreeRTOS-LwIP-debug download will not build but InVue.RTD-InVue_RTD-FreeRTOS-LwIP download will.
The error is related to the memory location defines in the OTA2_image_defines.mk.
Is this normal? How can I debug my project with the added OTA code?
Build Console
18:04:24 **** Build of configuration Default for project AWS_WIFI_RTD ****
"C:\\Firmware\\F1679_WIFI_RTD\\AWS_V2\\make.exe" -j8 InVue.RTD-InVue_RTD-FreeRTOS-LwIP-debug ota2_manuf_download
MAKEFILE MAKECMDGOALS=InVue.RTD-InVue_RTD-FreeRTOS-LwIP-debug ota2_manuf_download OTA2_SUPPORT is enabled
make.exe[1]: warning: -jN forced in submake: disabling jobserver mode.
Building Bootloader waf.ota2_bootloader-NoOS-NoNS-InVue_RTD-P103-SoC.43909
Building Serial Flash Loader App
Finished Building Serial Flash Loader App
prgm hdr cnt=3
total_size = 15756, entry_point = 0x688000
Loadsegment_offset = 0xA0 segment_size = 15520, segment_pad = 0
Loadsegment_offset = 0x3D40 segment_size = 32, segment_pad = 0
Loadsegment_offset = 0x3D60 segment_size = 204, segment_pad = 0
Finished Building Bootloader
apps/InVue/RTD/../../../libraries/filesystems/ota2/wiced_ota2_image.c: In function 'wiced_ota2_image_copy_uncompressed_component':
apps/InVue/RTD/../../../libraries/filesystems/ota2/wiced_ota2_image.c:577:19: error: 'OTA2_IMAGE_FLASH_BASE' undeclared (first use in this function); did you mean 'NORMAL_IMAGE_FLASH_BASE'?
dst_offset = (OTA2_IMAGE_FLASH_BASE + component_header->destination);
apps/InVue/RTD/../../../libraries/filesystems/ota2/wiced_ota2_image.c:577:19: note: each undeclared identifier is reported only once for each function it appears in
apps/InVue/RTD/../../../libraries/filesystems/ota2/wiced_ota2_image.c: In function 'wiced_ota2_image_write_data':
apps/InVue/RTD/../../../libraries/filesystems/ota2/wiced_ota2_image.c:1290:28: error: 'OTA2_IMAGE_STAGING_AREA_SIZE' undeclared (first use in this function); did you mean 'NORMAL_IMAGE_APPS_AREA_BASE'?
if ( (offset + size) > OTA2_IMAGE_STAGING_AREA_SIZE)
apps/InVue/RTD/../../../libraries/filesystems/ota2/wiced_ota2_image.c: In function 'wiced_ota2_get_boot_type':
apps/InVue/RTD/../../../libraries/filesystems/ota2/wiced_ota2_image.c:1590:14: warning: implicit declaration of function 'wiced_dct_ota2_read_saved_copy'; did you mean 'wiced_dct_read_with_copy'? [-Wimplicit-function-declaration]
result = wiced_dct_ota2_read_saved_copy( &ota2_header, DCT_OTA2_CONFIG_SECTION, 0, sizeof(platform_dct_ota2_config_t));
apps/InVue/RTD/../../../libraries/filesystems/ota2/wiced_ota2_image.c: In function 'wiced_ota2_image_get_offset':
apps/InVue/RTD/../../../libraries/filesystems/ota2/wiced_ota2_image.c:1796:26: error: 'OTA2_IMAGE_FACTORY_RESET_AREA_BASE' undeclared (first use in this function); did you mean 'NORMAL_IMAGE_DCT_2_AREA_BASE'?
ota_offset = OTA2_IMAGE_FACTORY_RESET_AREA_BASE;
apps/InVue/RTD/../../../libraries/filesystems/ota2/wiced_ota2_image.c:1799:26: error: 'OTA2_IMAGE_STAGING_AREA_BASE' undeclared (first use in this function); did you mean 'NORMAL_IMAGE_APPS_AREA_BASE'?
ota_offset = OTA2_IMAGE_STAGING_AREA_BASE;
tools/makefiles/wiced_elf.mk:232: recipe for target 'build/InVue.RTD-InVue_RTD-FreeRTOS-LwIP-debug/Modules/apps/InVue/RTD/../../../libraries/filesystems/ota2/wiced_ota2_image.o' failed
make.exe[1]: *** [build/InVue.RTD-InVue_RTD-FreeRTOS-LwIP-debug/Modules/apps/InVue/RTD/../../../libraries/filesystems/ota2/wiced_ota2_image.o] Error 1
make.exe[1]: *** Waiting for unfinished jobs....
Makefile:351: recipe for target 'main_app' failed
make: *** [main_app] Error 2
18:04:29 Build Finished (took 5s.190ms)
- Email to a Friend
I think I found the problem last night after posting. I was able to get the errors to go away by including the filesystems/wicedfs component in my makefile because my application requires access to functions in wiced_ota2_image.c.
- Email to a Friend
I don't see this problem when I tested snip.scan-CYW943907AEVAL1F-FreeRTOS-LwIP-debug ota2_manuf_download in WICED SDK 6.2.1. The build passed without any error. Are you using CYW43907 based platform? Can you test with snip.scan and confirm if you still see this issue? Perform a make clean and then test.
- Email to a Friend
