I'm trying to understand how the OTA works and am a bit confused about some of the example comments.
The comments in ota_fr.c talk about 8 slots being defined in the external flash (using BCM943362WCD4, 1Meg external flash).
One of the slots is reserved for the WIFI_FIRMWARE, BUT when I build my app, the WIFI_FIRMWARE is part of my binary/elf file.
So why would a slot be reserved for this? Is there a mechanism for breaking this out of my app and updating it independently?
I ask because the 1Meg external flash seems wholly inadequate. If your app has the OTA + WIFI code included in it, it is almost always going to be >500k. If you want to download a new image that is also >500k, it will not fit into the external flash (unless you erase the original image first).
If I can separate out the WIFI code (208k), then you could save ~208k on your default and OTA app images.
TIA.
Over The Air Updates (OTA)
SDK 3.x
SPI
