I am currently using WICED over SN8205.
How to perform OTA without external flash?
Consider that if we can rearrange the Internal Flash to have Bootloader/DCT/OTA-App/APP0.
On OTA trigger, the APP0 will reboot and boot to OTA-App.
The OTA-App can then reflash the APP0.
This implementation would not require the use of External Flash and as the Bootloader/DCT/OTA-App together is small, there should not be any size concern for APP0.
Can this be implemented?
Karthik
Memory
Over The Air Updates (OTA)
SDK 3.x
The implementation is possible, the only drawback is that we are limited to the internal flash size which can be halved.
You should make sure the internal flash could be execute during re-programing and erase!
If answer is yes! Then it's possible!
Check this link Re: OTA upgrade without FR on 3.1.2 Bassem have answer why ! !
Suppose all firmware is present in the internal flash, 0xaddress2 is at a predefined location -
0xaddress1 - APP0.elf
0xaddress2 - OTA_App.elf
Set boot to 0xaddress2, OTA_App will run will flash to 0xaddress1 which is not its own.
So should be possible?
I am not sure!
if you issue erase or program command to internal flash then the different flash address read back is same before !
But you could try! Just mention what I thought for this !
