Wi-Fi Combo Forum Discussions
prpuc_2175051
First like received
We are working on BCM43362 based WiFi Murata module with ARM Cortex M4 based platform. The WICED SDK version we are using is 3.5.2
From this link, How many clients are supported by the softAP?   we could find that maximum number of clients supported is 5.
When we tried setting this maximum client count to 5 using IOVAR_STR_MAX_ASSOC, we get return code as WWD_WLAN_RANGE, which means specified value is not in range. We could not find any information about this in README.txt as well. Is this value of 5 clients still valid with SDK version 3.5.2?
Where can we find latest/updated correct information about this?
Thanks & Regards,
Pratik.
Thanks for quick response.
