I install the WICED-SDK-3.3.1-IDE-Install.exe on Windows 7.  I can compile and dowload  the scan example using make target "snip.scan-BCM943362WCD4 download run". But I can'e see the build folder in project Explorer>WICED_SDK in Eclipse. I have to right click  to  Explorer>WICED_SDK and click "Refresh". then I can see the build folder.
VikramR_26
25 sign-ins 10 sign-ins 10 comments on KBA
Thanks for letting us know, we have seen this before. We should have fix in next build. We also noticed the doc folder not visible similarly.
When do you have the fix in next build?
