I don't know why I am having so much difficulty getting my environment going. I have downloaded and installed the Wiced Studio 6.2.2 on both my Macbook and my PC. In both cases I am seeing no platforms to work with and nothing in the Project Explorer. I am just trying to get to a starting point like in the Training 101 videos.
During installation it creates the following folder, but I feel like there should be more content here. I don't see any of the initial projects and can't seem to find how to get the intial environment working. I have a CYW94343WWCD1 Evaluation & Development board but I can't get passed what appears to be an incomplete installation. Any direction as to what I need to download and install?
I have tried importing folders and projects with no success. Screen shots of what I am seeing below.
MAC OSX
WICED Studio
Windows
- platform files
- setup
So I believe I solved my own problem by uninstalling 6.2 and installing the previous version 6.1. After this long process all of the files are in the SDK that were not present in the new release.
Someone might want to look at that.
Did you follow the detailed instructions for OSX here: WICED-Studio-6.2.1 (OSX)
OSX Install:
- Download the attached .zip file
- Double click the zip file and extract all contents from the installer to a local folder
- Note: When using the Safari Browser, it will automatically unzip the contents and create a folder
- Note: the next two steps below are needed as a workaround for a known OSX 10.12 install issue called "App Translocation"
- Move the contents of the folder to another folder using ‘Finder’; Do not move the files using ‘Terminal’
- Be sure to move the entire folder contents including the installer app file and config.eml.
- Run the command below using Terminal window:
> xattr -r -d com.apple.quarantine <path>/WICED-Studio-X.X.X.X-IDE-Installer.app
- See "Additional Installation Notes" below before installing
- Double click the "WICED-Studio-X.X.X.X-IDE-Installer" app to execute the installer
- After the installation in complete, launch the WICED Studio IDE from shortcut in the $HOME/Cypress $HOME/WICED/WICED-Studio-X folder
OSX Uninstall:
- From Finder, navigate to User > <name> -> Applications -> Cypress and launch 'Uninstall'
- To clean up all WICED components manually, delete files and folders for the IDE and SDK, typically in User -> <name> -> WICED/WICED-Studio-X and User -> <name> -> Documents -> WICED/WICED-Studio-X or from terminal $HOME/Cypress/WICED*, $HOME/WICED/WICED-Studio-X and $HOME/Documents/WICED/WICED-Studio-X
Additional Installation Notes:
1.
Open xterm, run the "java -version" command. If it fails to return any results or states that you are running version 1.6, then you need to install the Java SE Development Kit 8, which can be found here: http://www.oracle.com/technetwork/java/javase/downloads/jdk8-downloads-2133151.html. Once the Java SE Development Kit 8 is installed, run the "java -version" command again with xterm. If this command returns "1.6", then you will need to fix the symbolic link using the following commands:
> rm -f /usr/bin/java
> ln -s /System/Library/Frameworks/JavaVM.framework/Versions/Current/Commands/java /usr/bin/java
2.
Application downloads on WICED platforms may fail on certain OSX versions due to an incompatibility between the OSX version and the installed driver for the FTDI USB to serial chip. On OSX versions 10.10 and earlier, a specific version of the FTDI driver must be installed using the instructions available here: https://learn.sparkfun.com/tutorials/how-to-install-ftdi-drivers/mac
On OS X versions 10.11 and greater, the Apple version of the FTDI driver must be used, and any previous instance of the FTDI version of the driver must be removed from the system, by executing the following command in xterm:
> sudo rm -rf /Library/Extensions/FTDIUSBSerialDriver.kext /System/Library/Extensions/FTDIUSBSerialDriver.kext
Reboot the system after performing the rm command
So do you have any idea why the previous version 6.1 does not has such installation problem as brad replied.
Yes, I did follow the detailed instructions, but it simply looks like the Build just was missing all the files in the 43xxx_Wi-Fi folder. See below. These are the file folders immediately installed after the deployment of each of the SDK Version installers. I reproduced this on both Mac and PC installs. Look at the difference in the folders.
So you still have problem to install sdk-6.2, and you fallback to install sdk-6.1 instead.
My previous reply is for michael_c, as it looks like some change in sdk-6.2 causes the installation problem.
Adding the applications team so they can comment AnjanaM_61 GauravS_31 GyanC_36 PriyaM_16 RaktimR_11 SheetalJ_96WinstonF_61
Many have downloaded and installed 6.2.1 OSX and have not had the same problem.
The Apps team will need you to attach a copy of the 6.2.1 install log to this post so they can review.
Is the install log still present after it is uninstalled? Where should I
find that on a PC and a Mac.
On Fri, Jan 25, 2019 at 6:11 AM MichaelF_56 <community-manager@cypress.com>
On the Mac, the installer logs will be under: /tmp/wiced_install_log
So I tried to re-install 6.2 again today and still no files in the SDK Folder
Dropbox - WICED-Studio_Install_02_11_2019_11_58_34.log
Here is the install log. Can someone provide me with the SDK files?
Actually, I am using Studio in Win7 and Win10 , but not encounter this issue in my setting.
I do the install again in my Win10 laptop, and read some info for the environment setting for the Eclipse.
Most of the Eclipse SDK is "pure" Java code and has no direct dependence on the underlying operating system. The chief dependence is therefore on the Java Platform itself. Portions are targeted to specific classes of operating environments, requiring their source code to only reference facilities available in particular class libraries (e.g. J2ME Foundation 1.1, J2SE 1.4, Java 5, etc).
In general, the 4.4 release of the Eclipse Project is developed on a mix of Java SE 6 and Java SE 7 VMs. As such, the Eclipse SDK as a whole is targeted at all modern, desktop Java VMs. Most functionality is available for Java SE 6 level development everywhere, and extended development capabilities are made available on the VMs that support them.
Would you please check the appendix attached in your environment?
Did you take a look at brad's log?
e.g.
Execute Script/Batch file: call
Status: ERROR
Additional Notes: ERROR - Error while attempting to execute the installation script
>>>: C:\Users\htlas\AppData\Local\Temp\474116.tmp\executeScriptTmp0.bat
Command.run(): Cannot run program "C:\Users\htlas\AppData\Local\Temp\474116.tmp\executeScriptTmp0.bat": CreateProcess error=193, %1 is not a valid Win32 application
Thanks and yes, I noticed this error, it looks like a limited authority issue since the content of the .bat should be same with all of us.
So suggest checking the environment and rights of administrator in advance.
and checked my executeScriptTmp0.bat
cmd.exe /c "del "C:\Users\zhez\Desktop\install\WICED-Studio-6.2\install_config_win32.exe""
I think maybe the system is having problems to run "cmd.exe "
The log does not show any authority issue, but something else.
^^^^^^^^^^^^^^^^ What is %1 here
searching classpath contents...
in isJARBuiltForSystemi : classpath C:\Users\htlas\AppData\Local\Temp\I1549914951\Windows
Command.run(): starting stdout monitor...
Command.run(): starting stderr monitor...
Command.complete(): waiting for process to complete.
Command.run(): C:\Users\htlas\AppData\Local\Temp\474116.tmp\executeScriptTmp0.bat:stdout []
Command.run(): C:\Users\htlas\AppData\Local\Temp\474116.tmp\executeScriptTmp0.bat:stderr [The filename or extension is too long.]
Why it complains filename or extension is too long
Command.complete(): process completed with exit code: 1
Command.complete(): process 'C:\Users\htlas\AppData\Local\Temp\474116.tmp\executeScriptTmp0.bat' complete
Command.run(): C:\Users\htlas\AppData\Local\Temp\474116.tmp\executeScriptTmp0.bat:stderr [Could Not Find C:\Users\htlas\Documents\WICED-Studio-6.2\install_config_win32.exe]
^^^^^^ The file does not exist.
Actually, the directory in the log is not so long to cause the issue.
I found some info, maybe to enable the hidden files/folders will help this :
