No GATT_CONNECTION_STATUS_EVT when connection went down
RoHe_4370821
Level 4
Level 4
25 replies posted 25 sign-ins 10 replies posted
I'm using 4343W with WICED Studio SDK Version: Wiced_006.004.000.0061
During an overnight automated test, I found one occurrence of the BLE connection going down but the GATT callback did not get called with a GATT_CONNECTION_STATUS_EVT event. Is this known to be something that will happen occasionally? I had expected the GATT_CONNECTION_STATUS_EVT to always be called when a connection event occurs.
I can cover the lack of the connection-down event with an application timer, should this be necessary.
Regards.
DheerajPK_41
GATT_CONNECTION_STATUS_EVT  event is expected to be generated by the stack (usually) when a connection is made or broken. The event parameter tells you WICED_TRUE if connected, WICED_FALSE is connection broken.
If you observe occasional missing of the event, we may have to do further inspection about the issue.
-Dheeraj
DheerajPK_41
-Dheeraj
