Hi Support,
I am evaluating the cypress CYW943907AEVAL1F board and using SDK version 6.0.1.5. For example of TCP communication, I can see some apps in the snip for TCP client and TCP client power save.
Do you have any example application for TCP+SSL?
Or can you please guide me for how to load certificate and modify the TCP client application to use it with SSL?
I will use OpenSSL for opening the TCP server and I do have the required certificate for the connection . I am attaching the sample application that I am referring to and the certificate as well which needs to be loaded. The certificate that I have is in the .pem format.
Akash
Security
TCPIP
WICED Studio
Wireless MCU
- tcp+ssl
TCP+TLS is explained in WW101 chapter WW101-06b-Sockets-TLS.pdf available at https://github.com/cypresssemiconductorco/CypressAcademy_WW101_Files/tree/master/Labmanual. Please refer to sections 6B.2 X.509 CERTIFICATES and 6B.3 TCP/IP SOCKETS WITH TRANSPORT LAYER SECURITY (TLS).
All of the WICED training is also available here on the community: WICED Training Videos
