Using WICED Studio 6.6 and the development kit CYW943907AEVAL1F. I have a couple of issues. First, NDEBUG is being set somewhere and I can't locate where. Second, because of NDEBUG being set the definition of the assert macro becomes: assert(__e)((void)0). When the expression given evaluates to false, execution continues normally and does not pass an error message and abort. Any help is appreciated!
NDEBUG is enabled in file wiced_toolchain_ARM_GNU.mk or wiced_toolchain_ARM_GNU.mk located at WICED-Studio-6.6\43xxx_Wi-Fi\tools\makefiles\ by default. Seach -DNDEBUG in these files and you will see them. We can see it's enabled only in Release target by default.
And from the makefile note, you may explicitly activate option -debug to avoid being built in Release target, which gets you in current situation. See below for how to do it:
Notes
* Component names are case sensitive
* 'WICED', 'SDIO', 'SPI' and 'debug' are reserved component names
* Component names MUST NOT include space or '-' characters
* Building for release is assumed unless '-debug' is appended to the target
* Some platforms may only support a single interface bus option
Example Usage
Build for Release
$> make snip.scan-BCM943362WCD4
$> make snip.scan-BCM943362WCD4-ThreadX-NetX_Duo-SDIO
Build for Debug
$> make snip.scan-BCM943362WCD4-debug
