Using WICED Studio 6.6 and the development kit CYW943907AEVAL1F. I have a couple of issues. First, NDEBUG is being set somewhere and I can't locate where. Second, because of NDEBUG being set the definition of the assert macro becomes: assert(__e)((void)0). When the expression given evaluates to false, execution continues normally and does not pass an error message and abort. Any help is appreciated!
Debug
Linux
WICED Studio
NDEBUG is enabled in file wiced_toolchain_ARM_GNU.mk or wiced_toolchain_ARM_GNU.mk located at WICED-Studio-6.6\43xxx_Wi-Fi\tools\makefiles\ by default. Seach -DNDEBUG in these files and you will see them. We can see it's enabled only in Release target by default.
And from the makefile note, you may explicitly activate option -debug to avoid being built in Release target, which gets you in current situation. See below for how to do it:
Notes
* Component names are case sensitive
* 'WICED', 'SDIO', 'SPI' and 'debug' are reserved component names
* Component names MUST NOT include space or '-' characters
* Building for release is assumed unless '-debug' is appended to the target
* Some platforms may only support a single interface bus option
Example Usage
Build for Release
$> make snip.scan-BCM943362WCD4
$> make snip.scan-BCM943362WCD4-ThreadX-NetX_Duo-SDIO
Build for Debug
$> make snip.scan-BCM943362WCD4-debug
Notes
Example Usage
Build for Release
Build for Debug
