daboc_1706941
First like given
In the 43xxx_Wi-Fi folder, there is only one directory (tools).
My search for files normally found in other releases came up empty.
The files do appear to be in the Windows release of 6.2.1
MichaelF_56
Download v6.2.1 from here: WICED Studio Wi-Fi/Combo Docs & Downloads
Unzip BOTH files to a folder right off the C: drive, something simple with no spaces in it like \wiced
Double click the installer.
If you download the double click the exe inside the .zip the install will show the same symptoms you describe.  The files must first be save and reside in the same folder as one another when you execute.
If this continues to give you problems, post the install log from the %tmp%\wiced_install_log folder here and the applications team will take a look.
