Wi-Fi Combo Forum Discussions
What is the minimal stack size requirement for a thread doing almost nothing more that get/set a couple of semaphores: 256 bytes? 512? 1024? 2048? 4096? ...
Is it the same requirement for both RTOS (threadX/FreeRTOS) ?
Is there some Wiced framework components more stack greedy than others ?
Thanks for your answers.
Pascal.
SeyhanA_31
Creating a thread and passing a semaphore hook to the created thread to get/set semaphore, 256 bytes stack size is enough.
Ones you utilize the network stack more memory needs to be allocated for the thread.
Seyhan
