MaFa_974161
100 sign-ins 50 replies posted 50 questions asked
Hello.
I've developed a project for CYW954907AEVAL1F with WICED.
I want to migrate this project from WICED to MODUSTOOLBOX because I believe to understant in some threads that MODUSTOOLBOX has NetX-Duo library more updated than WICED.
Can someone help me ?
Aditi_B
500 replies posted 5 questions asked 250 replies posted
Is it possible to check your custom-developed example with the FreeRTOS+LwIP combination in WICED? WICED supports this combination as well as the default combination. For ex: snip.scan example can work with both of these combinations. It's just that for the FreeRTOS+lwIP combination, you've to specify in the make target.
<application>-<target_board>-FreeRTOS-LwIP download run
If you see the same issue of delay happening with this combination then it's not related to NetX_Duo+ThreadX.
With regards to WICED future support, I don't have a firm answer on this. I've to confirm this internally. I'll get back to you on this.
Aditi
Aditi_B
May I know which project is this? Is it a snip application or a custom-developed?
Aditi
MaFa_974161
I developed a custom project on a new product that we are planning to release on the market.
Do you suggest to review the project by switching from WICED to Modus Toolbox?
Are you planning to stop WICED support in the future ?
Aditi_B
I would suggest reviewing the project in Modus Toolbox but MODUS currently supports lwIP+FreeRTOS combination only. You will have to port the NetX_Duo network stack and the ThreadX RTOS in MODUS to use this combination.
Aditi
OK ...
but Infineon is planning to stop WICED support  and is going to develop only on Modus Toolbox ?
Porting my project from NetX_Duo ThreadX to LwIP Free RTOS is expensive and require  a lot of time that we haven't
My project send UDP packets on a Tablet and act as a server in a specific TCP port.
In some tablets I notice a lot of UDP packets lost and big delay on TCP packets.
Is it a problem related to NetX_Duo ThreadX ?
Do you know if LwIP Free RTOS has this problem ?
Aditi_B
Aditi
