03:42 PM
Oct 22, 2015
03:42 PM
What's the maximum number BLE connections possible when using SDK 3.3.1+ on a BCM43340 or BCM4343W? Is it possible to connect to more than one central at a time?
Labels
Wifi+Bluetooth
- ble
11:02 AM
Jan 26, 2016
11:02 AM
Hello andrew997
The Max # of simultaneous BLE connection depends on the hardware memory availability. I believe for BCM4343W it is somewhere between 4-5 Connections.
Also you can not connect central to another central, to make a connection you will have to configure the other broad to be peripheral.
I hope this helps,
Rj
