After a "make clean", building the ota_fr sample application, or for that matter any application with target "download_apps", results in a crash of the make. Host is Linux kubuntu 64-bit. Running as root or for the BCM943362WCD4 target results in the same crash.
Showing below the last few output lines of the command:
WICED-SDK-3.1.2$ ./make snip.ota_fr-BCMUSI14 JTAG=Olimex_ARM-USB-TINY-H VERBOSE=1 download download_apps run
Making snip_ota_fr-BCMUSI14.elf
"./tools/ARM_GNU/bin/Linux64/arm-none-eabi-g++" --static -Wl,-static -Wl,--warn-common -o build/snip_ota_fr-BCMUSI14/binary/snip_ota_fr-BCMUSI14.elf @build/snip_ota_fr-BCMUSI14/binary/link.opts
"./tools/common/Linux64/echo"
"/usr/bin/perl" ./tools/mapfile_parser/map_parse_gcc.pl -a build/snip_ota_fr-BCMUSI14/binary/snip_ota_fr-BCMUSI14.map > build/snip_ota_fr-BCMUSI14/binary/snip_ota_fr-BCMUSI14_map.csv
"./tools/ARM_GNU/bin/Linux64/arm-none-eabi-strip" -o build/snip_ota_fr-BCMUSI14/binary/snip_ota_fr-BCMUSI14.stripped.elf build/snip_ota_fr-BCMUSI14/binary/snip_ota_fr-BCMUSI14.elf
"/usr/bin/perl" ./tools/mapfile_parser/map_parse_gcc.pl build/snip_ota_fr-BCMUSI14/binary/snip_ota_fr-BCMUSI14.map
echo Making snip_ota_fr-BCMUSI14.bin
"./tools/ARM_GNU/bin/Linux64/arm-none-eabi-objcopy" -O binary -R .eh_frame -R .init -R .fini -R .comment -R .ARM.attributes build/snip_ota_fr-BCMUSI14/binary/snip_ota_fr-BCMUSI14.stripped.elf build/snip_ota_fr-BCMUSI14/binary/snip_ota_fr-BCMUSI14.bin
| | Static |
Module | Flash | RAM |
App | 293 | 0 |
base64 | 518 | 0 |
DHCP_Server | 1510 | 132 |
DNS | 64 | 44 |
Host MCU-family library | 14411 | 2484 |
Interrupt Vectors | 424 | 0 |
libc | 33976 | 3136 |
Networking | 3658 | 14318 |
NetX | 54658 | 536 |
NetX-Duo - Interfaces & Stacks | 0 | 12 |
OTA_Server | 8239 | 676 |
Packet Buffers | 0 | 23142 |
platform | 1300 | 168 |
RAM Initialisation | 2416 | 0 |
resources | 16 | 0 |
Ring_Buffer | 92 | 0 |
SPI_Flash_Library_BCMUSI14 | 636 | 0 |
Startup Stack & Link Script fill | 22 | 4 |
Supplicant - BESL | 89988 | 516 |
ThreadX | 9168 | 396 |
Wi-Fi Firmware | 213212 | 0 |
WICED | 2843 | 820 |
WWD | 13416 | 1112 |
TOTAL (bytes) | 448444 | 47496 |
"./tools/common/Linux64/mkdir" -p build/eclipse_debug/
echo Downloading Bootloader ...
"./tools/OpenOCD/Linux64/openocd-all-brcm-libftdi" -f ./tools/OpenOCD/Olimex_ARM-USB-TINY-H.cfg -f ./tools/OpenOCD/stm32f2x.cfg -f ./tools/OpenOCD/stm32f2x-flash-app.cfg -c "verify_image_checksum build/waf_bootloader-NoOS-NoNS-BCMUSI14-SDIO/binary/waf_bootloader-NoOS-NoNS-BCMUSI14-SDIO.stripped.elf" -c shutdown >> build/openocd_log.txt 2>&1 && echo No changes detected && "./tools/common/Linux64/echo" || "./tools/OpenOCD/Linux64/openocd-all-brcm-libftdi" -f ./tools/OpenOCD/Olimex_ARM-USB-TINY-H.cfg -f ./tools/OpenOCD/stm32f2x.cfg -f ./tools/OpenOCD/stm32f2x-flash-app.cfg -c "flash write_image erase build/waf_bootloader-NoOS-NoNS-BCMUSI14-SDIO/binary/waf_bootloader-NoOS-NoNS-BCMUSI14-SDIO.stripped.elf" -c shutdown >> build/openocd_log.txt 2>&1 && echo Download complete && "./tools/common/Linux64/echo" || echo "**** OpenOCD failed - ensure you have installed the driver from the drivers directory, and that the debugger is not running **** In Linux this may be due to USB access permissions. In a virtual machine it may be due to USB passthrough settings. Check in the task list that another OpenOCD process is not running. Check that you have the correct target and JTAG device plugged in. ****"
Segmentation fault (core dumped)
make: *** [main_app] Error 139
marco@kubuntu:~/fogsense/WICED-SDK-3.1.2$ file core
core: ELF 64-bit LSB core file x86-64, version 1 (SYSV), SVR4-style, from './tools/common/Linux64/make -r -j4 -f ./tools/makefiles/wiced_elf.mk snip/ota_f'
Please advise.
-Marco G.
Have a look at http://community.broadcom.com/thread/4456?sr=stream&ru=17953
and see if the uploaded make file solves your problem.
