Hi.
I am having problems reconnecting upon an disconnect.
I am using WICED_SDK_3.5.1 and using secure MQTT (i.e. over TLS).
static wiced_result_t mqtt_connection_event_cb( wiced_mqtt_object_t mqtt_object, wiced_mqtt_event_info_t *event )
switch ( event->type )
case WICED_MQTT_EVENT_TYPE_DISCONNECTED:
if(reconnecting != WICED_TRUE) {
printf("Uh-Oh, I got disconnected in %s...\n", __FUNCTION__);
expected_event = event->type;
wiced_rtos_set_semaphore( &msg_semaphore );
reconnecting = WICED_TRUE;
iot_mqtt_connect();
break;
static void iot_aws_mqtt_reconnect()
mqtt_conn_close( mqtt_object );
mqtt_app_unsubscribe( mqtt_object, DELTA_TOPIC );
wiced_rtos_deinit_semaphore( &msg_semaphore );
WPRINT_APP_INFO(("[MQTT] Deinit connection in %s...\n", __FUNCTION__));
wiced_mqtt_deinit( mqtt_object );
wiced_rtos_deinit_semaphore( &wake_semaphore );
free( mqtt_object );
mqtt_object = NULL;
iot_mqtt_connect();
void iot_mqtt_connect( void )
wiced_result_t ret = WICED_SUCCESS;
uint32_t size_out = 0;
int connection_retries = 0;
int retries = 0;
int count = 0;
char* msg = SHADOW_PUBLISH_INVERTER_OFF;
/* Get AWS root certificate, client certificate and private key respectively */
ret = resource_get_readonly_buffer( &resources_apps_DIR_secure_mqtt_DIR_TestSolPadThing_DIR_rootCA_pem, 0, MQTT_MAX_RESOURCE_SIZE, &size_out, (const void **) &security.ca_cert );
ret = resource_get_readonly_buffer( &resources_apps_DIR_secure_mqtt_DIR_TestSolPadThing_DIR_cert_pem, 0, MQTT_MAX_RESOURCE_SIZE, &size_out, (const void **) &security.cert );
if(size_out < 64)
WPRINT_APP_INFO( ( "\nNot a valid Certificate! Please replace the dummy certificate file 'resources/app/aws_iot/client.cer' with the one got from AWS\n\n" ) );
return;
ret = resource_get_readonly_buffer( &resources_apps_DIR_secure_mqtt_DIR_TestSolPadThing_DIR_privKey_pem, 0, MQTT_MAX_RESOURCE_SIZE, &size_out, (const void **) &security.key );
if(size_out < 64)
WPRINT_APP_INFO( ( "\nNot a valid Private Key! Please replace the dummy private key file 'resources/app/aws_iot/privkey.cer' with the one got from AWS\n\n" ) );
return;
/* Disable roaming to other access points */
wiced_wifi_set_roam_trigger( -99 ); /* -99dBm ie. extremely low signal level */
/* Bring up the network interface */
ret = wiced_network_up( WICED_STA_INTERFACE, WICED_USE_EXTERNAL_DHCP_SERVER, NULL );
if ( ret != WICED_SUCCESS )
WPRINT_APP_INFO( ( "\nNot able to join the requested AP in %s...\n", __FUNCTION__));
return;
/* json register parser */
wiced_JSON_parser_register_callback(parse_json_control_message);
/* Allocate memory for MQTT object*/
mqtt_object = (wiced_mqtt_object_t) malloc( WICED_MQTT_OBJECT_MEMORY_SIZE_REQUIREMENT );
if ( mqtt_object == NULL )
WPRINT_APP_ERROR(("Dont have memory to allocate for mqtt objectin %s...\n", __FUNCTION__));
return;
WPRINT_APP_INFO( ( "Resolving IP address of MQTT broker in %s...\n", __FUNCTION__));
ret = resolve_dns_to_ip(MQTT_BROKER_ADDRESS, &broker_address);
if ( ret == WICED_ERROR || broker_address.ip.v4 == 0 )
WPRINT_APP_INFO(("Error in resolving DNS in %s...\n", __FUNCTION__));
return;
wiced_rtos_init_semaphore( &wake_semaphore );
wiced_mqtt_init( mqtt_object );
wiced_rtos_init_semaphore( &msg_semaphore );
do
WPRINT_APP_INFO(("[MQTT] Opening connection in %s...\n", __FUNCTION__));
do
ret = mqtt_conn_open( mqtt_object, &broker_address, WICED_STA_INTERFACE, mqtt_connection_event_cb, &security );
connection_retries++ ;
} while ( ( ret != WICED_SUCCESS ) && ( connection_retries < WICED_MQTT_CONNECTION_NUMBER_OF_RETRIES ) );
WPRINT_APP_INFO(("Failed in %s...\n", __FUNCTION__));
return;
WPRINT_APP_INFO(("Success in %s...\n", __FUNCTION__));
reconnecting = WICED_FALSE;
WPRINT_APP_INFO(("[MQTT] Subscribing in %s...\n", __FUNCTION__));
do
ret = mqtt_app_subscribe( mqtt_object, DELTA_TOPIC, WICED_MQTT_QOS_DELIVER_AT_MOST_ONCE );
retries++ ;
} while ( ( ret != WICED_SUCCESS ) && ( retries < MQTT_SUBSCRIBE_RETRY_COUNT ) );
failed_subscribe = WICED_TRUE;
return;
/* configure push button to publish a message */
wiced_gpio_input_irq_enable( WICED_BUTTON1, IRQ_TRIGGER_RISING_EDGE, publish_callback, NULL );
while ( reconnecting != WICED_TRUE )
wiced_rtos_get_semaphore( &wake_semaphore, WICED_NEVER_TIMEOUT );
if ( pub_in_progress == 1 )
WPRINT_APP_INFO(("[MQTT] Publishing in %s...\n", __FUNCTION__));
if ( count % 2 )
msg = SHADOW_PUBLISH_INVERTER_ON;
else
do
ret = mqtt_app_publish( mqtt_object, WICED_MQTT_QOS_DELIVER_AT_LEAST_ONCE, (uint8_t*) STATE_TOPIC, (uint8_t*) msg, strlen( msg ) );
retries++ ;
} while ( ( ret != WICED_SUCCESS ) && ( retries < MQTT_PUBLISH_RETRY_COUNT ) );
WPRINT_APP_INFO((" Failed in %s...\n", __FUNCTION__));
failed_publish = WICED_TRUE;
return;
else
WPRINT_APP_INFO((" Success in %s...\n", __FUNCTION__));
pub_in_progress = 0;
count++ ;
wiced_rtos_delay_milliseconds( 100 );
wiced_rtos_delay_milliseconds( MQTT_DELAY_IN_MILLISECONDS * 2 );
} while ( reconnecting != WICED_TRUE );
AWS
Cloud
SDK 3.x
TCPIP
Web Services
rcnmartell xavier@candyhouse mkochhal
I just tried this
aws_mqtt_app_subscribe( app_info.mqtt_object, app_info.shadow_delta_topic , WICED_MQTT_QOS_DELIVER_AT_MOST_ONCE );
Change the subscribe QoS to 0 .
It works fine.
Also make sure to clean to and then download.
Let me know if this resolves ?
