Hi Sir,
Does Broadcom have a EVB which has MFi Auth IC SMT on it already? thanks!
James
YU,
What I did is working with our customers who has MFi licensee then mount chip on our board. Thanks,
Roy
GregG_16
50 sign-ins 25 sign-ins 25 comments on KBA
We have the boards that have everything but the AUTH IC is not populated. We can not provide the AUTH IC, but it just needs to be soldered on.
Is the board you means "BCM9WCDPLUS114"? thanks!
I saw that. thanks!
For WICED Audio, broadcom support airplay in the coming soon SDK3.1 release, right? and the ref board is BCM9WCD1AUDIO_3, and I also didn't find the auth IC chip design on it. So does it means customer need build up an dedicated PCBA with auth IC, which can connect to  BCM9WCD1AUDIO_3 via I2C interface? Or else, it is not possible to do the airplay audio demo.
Broadcom can not provide the Auth IC.  So you have to get it from MFI procurement site.  Is this your question?
Got it, thanks!
Cheers!
James Sun
Office: SHA:86 21 61958367|SZ:86 755 33322929|Cell: 86 189-3096-5899<tel:86%20189%203096%205899>
