- Email to a Friend
When could we expect support for the LwIP Chained Buffers?
At the moment, Wiced does not properly support LwIP without this. The Chained Buffers are a core feature of LwIP which cannot be deactivated.
My previous post was closed as Solved but the issue itself is not: https://community.infineon.com/t5/Wi-Fi-Combo/low-level-output-asserting-with-quot-No-chained-buffer...
Thanks for your support,
WICED Studio Wi-Fi Combo
- Email to a Friend
Hi @BeOl_4470266 ,
Can you share the example code which you are using when you faced the problem mentioned in previous post.
Thanks & Regards,
Rakesh B G
- Email to a Friend
Thanks for your answer.
I don't have a practical subset of code to provide, but that should not be necessary anyway: the problem was clearly identified in the previous post on this subject.
Thanks in advance for your support on this product,
- Email to a Friend
This is nothing to do with application code.
lwIP supports chained pbuf and you can not stop it to do that.
(A packet may span over multiple pbufs, chained as a singly linked list. This is called a "pbuf chain".)
So the driver *must* take care of chained pbuf.
- Email to a Friend
I too have a problem with this issue. The support for chained buffers is clearly missing and needs implemented. I see frequent TCP errors that I assume are as a result of this issue. I have attached a screenshot of the assertion that is hit in the debugger.
Rob
- Email to a Friend
- Email to a Friend
Dear Infineon Support,
This issue needs to be fixed, as it is causing your customers products to have networking issues. A solution needs to be implemented.
Rob
- Email to a Friend
@Rakesh_BG wrote:
Hi @BeOl_4470266 ,
There is no plan to support lwIP buffer chaining in wiced.
This is not requesting any new feature, but a bug fix.
Please clarify if the support team will fix this BUG or not.
I don't think people can wait endless here.
- Email to a Friend
I think 3 possible ways to address this bug.
1. Make WWD driver support chained pbuf
2. Hack lwIP to prevent chain pbuf
3. Convert chained pbuf into a single large pbuf before pass to WWD
You know people already hit this issue, the bug is real. This issue needs urgent fix.
- Email to a Friend
@RaktimR_11 @Rakesh_BG @AditiB_81
The "No chained buffers" assertion is also reported here: (Jun 05, 2019)
https://community.infineon.com/t5/Wi-Fi-Combo/iperf-with-LWIP-FreeRTOS/m-p/169566
Why there is no fix for more than 2 *years*.
