Wi-Fi Combo Forum Discussions
MaFa_974161
100 sign-ins 50 replies posted 50 questions asked
Hello.
I'm using WICED.
I configured WICED as AP with this settings in "wifi_config_dct.h" ...
#define SOFT_AP_SSID "WICED Device"
#define SOFT_AP_CHANNEL 1
#define SOFT_AP_SECURITY WICED_SECURITY_WPA2_AES_PSK
#define SOFT_AP_PASSPHRASE "12345678"
I want to know if there is a way to limit the number of connected STA to just only one Station.
As @Leo_Liu2 said you can either uncomment the macro in /43xxx_Wi-Fi/WICED/WWD/WWD.mk or since it is a GLOBAL define, even defining it in your application makefile should also work.
Leo_Liu2
25 sign-ins 10 sign-ins 5 replies posted
You can uncomment  below param in WWD.mk to configure max number of associated STA for SoftAP :
GLOBAL_DEFINES += WWD_WIFI_CONFIG_AP_MAX_ASSOC=1
MaFa_974161
If I add this param in my *.mk project ?
MaFa_974161
yes, it works
