SeyhanA_31
I am using BCM943362WCD4 EVAL board.
On board, The JTAG LED is high ( Even when not Programming) .
What may be the reason, And What its solutions.
SeyhanA_31
JTAG LED is driven by the JTAG_CLK signal.
By default the JTAG_CLK is high and LED is being driven by the NTS4001NT1G. After the board is programmed the JTAG_CLK is kept low and LED is not driven.
Seyhan
Hi seyhan,
Thanks Seyhan  For quick Reply,
On the board, AFTER Programming is finished, Than also The J-TAG LED is keep High. It's Not low after Programming.
What may be the reasons, And What may be the solutions. ?
Need Help In this Matter.
Thanking You,
Hinesh
