I'm having an issue where I never get a scan complete event in my application containing critical sections (aka, scheduler and interrupts disabled). If I try running the example scan snippet, I see that a scan complete event occurs; however, in my application it does not. I have determined that this error occurs due to never receiving scan complete event from the 43362 chipset. I determined this by inspecting the status of every ASYNCEVENT_HEADER message in the event handler loop of 'wiced_process_sdpcm' in 'SDPCM.c' and logging any messages containing the correct status value.
Now, I'm running WICED 2.3.1, not 2.4.x. I understand that 2.4.x resolves some issue with SDIO Bus reliability. Is this the issue I'm seeing? Or is there something else that can trigger what I'm encountering?
-Dan
SPI
Scratch all that. It appears to be a memory corruption issue with the section of code. I'll address this later, but for now I'm leaving it out.
