Wi-Fi Combo Forum Discussions
jesubalan
First solution authored First reply posted First question asked
Hi ,
I am getting the below issue when I updated the MFG Test Application in Murata board. I haved updated the external flash with respective APPS.bin,filesystem,etc
** ERROR: WLAN: could not download clm_blob file
** FATAL ERROR: system unusable, CLM blob file not found or corrupted.
Is any extra thing need to be added in mfg_test.mk?
jesubalan
Hi Murali,
I haved found the issue is with WIFI_FIRMWARE_BIN := firmware/$(WLAN_CHIP)/$(WLAN_CHIP)$(WLAN_CHIP_REVISION)-mfgtest.bin
After That I changed it to WIFI_FIRMWARE_BIN := firmware/43438/43438A1-mfgtest.bin
Now it is working fine , Thanks for your Reply
MuraliR_36
Moderator 250 sign-ins 250 replies posted 100 solutions authored
Which chipset is this and which IDE are you using? Also, what is the app that is being used?
jesubalan
Hi Murali,
The Chipset is Murata Type1LD LBEE5PA1LD and the IDE is wiced studio
we are using the apps->test->mfg_test Application
MuraliR_36
what is your build string? test.mfgtest-<platform> download run?
jesubalan
It's test.mfg_test-MurataType1LD download download_apps run
jesubalan
Hi Murali,
