Jan 27, 2022
11:00 PM
Jan 27, 2022
11:00 PM
04:29 AM
Mar 28, 2022
04:29 AM
You can use Segger's JFLASH to program the application code in RAM. You can try building the application and using the elf/hex file to program the RAM but make sure that the boot process is not broken as the default process loads various files/firmware from the external flash to RAM.
Aditi
