Jan 27, 2022
11:00 PM
Jan 27, 2022
11:00 PM
04:29 AM
Mar 28, 2022
04:29 AM
You can use Segger's JFLASH to program the application code in RAM. You can try building the application and using the elf/hex file to program the RAM but make sure that the boot process is not broken as the default process loads various files/firmware from the external flash to RAM.
Aditi
02:46 AM
Jan 28, 2022
02:46 AM
Are you referring to WLAN (radio) firmware or the application code?
Aditi
Jan 28, 2022
04:29 AM
Jan 28, 2022
04:29 AM
The application code
Mar 28, 2022
04:29 AM
Mar 28, 2022
04:29 AM
Aditi
