Hi all,
Does anyone have the orCad part library created for the CYW43455 and/or a recommended reference design for using the 2g/5g/bt SoC ?
PCBLayout
Wifi+Bluetooth
Thanks. Our applications requires the use of an external antenna which sadly rules out most modules. I will contact the local sales team. Thanks
I am looking into where we are with regards to the broad market launch of the CYW943455EVB_02.
More to follow.
sgup
The CYW943455EVB_02 EVK will be released in conjunction with the next version of the SDK (v7.0). We normally provide schematic, gerber, BOM and layout files with each EVK release.
The EVK will leverage the Murata 1MW, which is a certified module based on the 43455. As sgup alluded to, chip down un-certified designs are typically not supported within the broad market due to complexity.
Thanks - will contact Murata also.
What is the expected timeline for WICED 7.0?
Hi Jason,
Are you looking for orcad symbol for CYW43455 silicon or module? We do not recommend chip-on-board designs using Wi-Fi / combo devices due complexity involved to get best performance and design something that passes certifications. If you are looking for symbol for module, I would recommend to get in touch with the module vendor based on the module that you are using. If you have not selected a module yet, please refer to module the selector guide at IoT Solutions Guide
Let us know if that addresses your question.
Sachin
Laird has the Sterling LWB5 which supports .ac and external antenna options, pre-certified (CYW43353 based).
Sterling-LWB5 Wi-Fi plus Bluetooth Module | LairdTech
Dual-Band 802.11ac Wi-Fi + Bluetooth v4.2 Module
This fully certified solution supports IEEE 802.11a/b/g/n/ac WLAN, BT 2.1+EDR, and BLE 4.2 wireless connectivity and is ideal for products utilizing either a Linux or Android-based microprocessor. With three module options, an industrial temperature rating (-40° to +85° C), and an industry-leading breadth of certifications and antenna options, the Sterling-LWB5 gives developers significant flexibility in meeting their design requirements.
- 802.11ac for high-speed data applications in the 5 GHz band
- Three configuration options available:
- SiP Module (10 mm x 10 mm x 1.6 mm)
- Module with chip antenna (21 mm x 15.5 mm x 2.3 mm)
- Module with external U.FL antenna port (21 mm x 15.5 mm x 2.3 mm)
- Antenna and U.FL Module versions are both footprint and pin compatible with Sterling-LWB (CYW4343W based)
Thanks for this. Looks like the module is about $25 which unfortunately puts it out of reach for our project.
ModusToobox will be launched in Q4.
http://www.cypress.com/products/modustoolbox-integrated-design-environment-ide
