Wi-Fi Combo Forum Discussions
Is possible buy only BCM43362 chip without host  stm32?
Now for test , in future for production.
I biuld very small accessories for homekit apple standard. Today i try localise in web distribution . No success.  In my project i need many IO  pin port . Now i test bcm943362wcd4eval and this eval is no eval for me. This board has no free port on pcb. I need connect:
relay,
led diodes,
power meter,
temperature control,
OLED display i2c controlled
external flash memory for data
switch on/off/configure
All modules as bcm943362wcd4 , murata sn8000 is to big.
, and more. My decision is build my version eval board for my project. where i buy bcm43362 chips without pcb ?? Mouser.com replay me - not offer this module.
GregG_16
25 sign-ins 25 comments on KBA 10 comments on KBA
SN8000 is the Radio Only version of 43362. We have this blog to get you some GPIO control on WCD4 board.
Re-purpose GPIO in Evaluation Board To Drive Motors
Inventek has some "radio only" modules too.
1. sn8000 is bigger than bcm43362 , i build wall plug , small electronic accessorium.
When i test broadcom eval bcm943362wcd4eval , for me normal situation is in offert.
Please tell me , i need buy bcm43362 chip , not module, not sn8000. where is problem ?
broadcom offer this only in modules with host? I can build proffessional accessories, super design, smaller,  wiced wifi not offer me ?
Yes, each WiFi module with antenna have a different form factor and they may not work for your application,
For BCM43362 SiP please contact your local Broadcom sales representative, Manufacturer's Representatives | Broadcom. If you like Wifi modules with and without antennas, please contact Broadcom WICED partners, Partners.
Seyhan
How about this one,
Communication Misc bcm43362 Parts - Avnet Express
But I think, if you use only BCM43362 chip, you also have to design own antenna and get own certification. And as seyhan mention, WiFi module with antenna have a different form factor. To design a efficient antenna, you need to have enough knowledge on antenna design.
